It is currently Sun Jul 20, 2025 8:48 am
PostPosted: Wed Jan 09, 2013 9:56 pm
First name: Richard
Last Name: Sprouse
City: Spartanburg
State: SC
Zip/Postal Code: 29302
Ok, this seems to me to be a silly question but I just pick up a bolt on electric and took the neck off to inspect the serial #. When I replaced the neck the action changed quite a bit ( much lower) lots of fret buzz. Whats going on?
Richard
PostPosted: Thu Jan 10, 2013 5:36 am
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Was there a shim under the neck when you took it off? A little piece off paper, something like a part of a match pack?
Brian
PostPosted: Thu Jan 10, 2013 1:22 pm
First name: Rodger
Last Name: Knox
City: Baltimore
Zip/Postal Code: 21234
In answer to your "What's going on?" question, you changed the neck angle slightly when you replaced the neck. Bolt-on necks frequently have a thin shim to refine the neck angle, and very small differences are noticible.
You can either take the neck off and re-shim it, or you may be able to raise the bridge slightly.
PostPosted: Fri Jan 11, 2013 10:40 pm
First name: James
State: Maine
With no string tension, saddle adjusters easily move around on their own as well. If not a missing neck shim, it's possible your bridge saddles moved lower.
PostPosted: Sat Jan 12, 2013 5:31 am
Look around on the floor below where you removed the neck for the shim, if it didn't fall off onto the bench. It'll be a small rectangular piece of wood or business card type material. Or a piece of an actual business card even!
Old growth, shmold growth!
PostPosted: Sat Jan 12, 2013 4:00 pm
First name: Mark
Last Name: Sorrentino
The OP has left the building. Must not have been a very important instrument.
PostPosted: Mon Jan 14, 2013 10:33 am
First name: Christopher
Last Name: Parker
City: Fatetteville
State: AR
Zip/Postal Code: 72701
H i guys - first post: Another possibility (aside from a missing neck shim) - the neck screws may be threading into the holes in the body, and it's in some sort of bind. It's best for holes in the body to be large enough so that the screws pass through without threading into it, otherwise there is potential for the neck to not sit flush against the bottom of the neck pocket.
PostPosted: Tue Jan 15, 2013 11:35 pm
First name: Aaron
Last Name: Thompson
City: Atlanta
State: Ga
Zip/Postal Code: 30308
Yep. Sounds like a lost shim to me. It's happened to me before, but I caught it before reassembling, luckily.
"I'm not going to say that perfection has never been achieved. However, if it has, it probably went unnoticed due to it's lack of character."
